Vokera 24
13 Nov 2005
Kent
Hi all
I have a Vokera 24, it seems to have a few faults
1, The tape water heats up to temperature then goes cold then heats up again and so on and on ...............!
2, When the heating (radiators) kick in the pressure gauge goes up and up, reaching as high as 4 bar (the starting point is one bar). The fill loop is off and the stops applied.
3, Water comes out of the pressure release outside the house.
4, when the heating turns of it makes a graunching sound twice, there is also a small bubbling sound whilst the heating running.
Could anyone please give me there thought on what they think could be the problem, and advise on a remedy.
Thanx Chris :twisted:
Hello... 1, sounds like a restricted/sludged up water to water heat exchanger.
2,3, are related and requires the expansion vessel to be recharged to its correct pressure. Also if its been doing it for a while the pressure relief valve could be kaput.
4, not too sure but could be related to the above.
hope that helps a little
I've ordered the parts, fingers crossed
Thanx
What parts have you ordered and what is your plan of action?
Changing parts without diagnosing the defect is the quick path to slippery slope that can and often burns a hole in your pocket.
What if the parts you intend replacing are not faulty.
I have seen boilers on tips and in skips with new parts fitted. A few months ago I saw a boiler (Vaillant VCW 242) in a skip that had been fitted with a new water section, diverter and a new pump. Couple of PCBs had been replaced as well.
Domestic heat exchanger, Expansion Vessel
