Hi hope someone can help. The expansion vessel (EV) seems to be knackered as water comes out of the schreader valve (car tyre valve) when pressed. The pressure valve is also leaking (water out of overflow pipe outside) and small drip inside, again more signs that the pressure has increased at some point and is not seating after being disturbed. I want to fit an external expansion vessel (12 litres as we have 11 radiators). Due to space (no room under or to side of boiler) I wanted to disconnect the old pancake expansion vessel and connect the flexible pipe which went to it , via an isolation valve and copper pipe to a new external expansion vessel. There is room above boiler for external EV and space for the copper pipe to fit up the back of the boiler.
Can someone tell me fittings I need (sizes) so I can get all the bits in one go. I assume I just close flow and return valves on CH under boiler (quarter turn to close ???) ,catch water from old EV and connect new one up and do the normal checks (1 bar air in EV with 0 system pressure etc).
One last thing, I have heard the isolation valves leak if disturbed, is it better to jst drain the CH system (I have new Sentinel inhibitor to go in anyway).
Martin.
Martin.
