my boiler when switched on gradually rises from 1 bar to 3 bar and leaks water from the prv outlet. when i de pressurise system back to 1 bar and switch on the same happens, but otherwise the boiler appears to operate normally? any help would be appreciated
Went to one a few weeks ago (a compact) and upon inspecting got a considerable amount of water out at pressure. Was about to book in for new one, but gave it another go to which it eventually stopped and then just needed a re-charge?
How that much water got in there in the first place? I know theres usually a dribble..
