Vokera Compact 29a Shudders/vibrates when switching off hot water
2 Mar 2012
Thanks to all that successfully helped before on an earlier thread regard this same boiler
Previous issue was a AAV but the shuddering was occasionally happening before the AAV issue and now afterwards
On turning hot tap off , short or long run of hot water the boiler shudders and makes a groaning sound bit like a dinosaurs growl made in films
Still works perfectly ok but does it occasionally , sometimes long shudder sometimes short vibration and shudder no particular pattern
Any ideas ?
Is it an inherent fault with these boilers
Anything to worry about ?
Etc etc
Thanks again in anticipation of any help
Could be a combustion problem, best to get it checked out, get it serviced by Vokera direct and you know it will be done properly and not a poke and go
thanks for prompt reply
could it be still be a combustion issue if it only happens when turning off hot water and the burners are turning off ?
Turning on hot water and hearing burners fire up is no problem ...just hear a click no vibration and get hot water
thanks again for any assistance
yes
