Hi all,
new here and hoping someone can help.
I have a Vokera Linea 24 Combi Boiler and the thing has over the last ten years been nothing but a PITA seems like every third winter it throws a flakey, leaving us with no heating and no hot water and guess what it's that time again! Last time was the PCB which was replaced.
This time the fault has been happening for a couple of months but a reset usually clears it but the problem is now permament but at least we are not chasing some form of intermittent fault.
Basically when on heating or hot water or both the boiler is igniting for three seconds and then cutting out, the LED is staying lit as green and no fault code is being shown which is the confusing part!!!
Heating engineer was onsite and investigated but says he has never seen this before, he checked the system by running through the fault diagnosise as layed out in the manual but could find nothing definate. His best guess is that the PCB or Gas Valve needs replaced. So he reckons maybe £300 to repair with no guarentee that the fault will be rectified in which case it maybe better to go with a new boiler.
While I now hate the thing with a vengance I am still loath to replace it if repairable at reasonable cost. I figure that I can buy at PCB and install it myself as stop gap, no I'm not an engineer but reasonably adept with most things so am thinking why not? Under no circumstances do I intend to touch the gas side, so if the PCB fails to resolve the problem I would have to have the engineer back to install the gas valve.
Hopefully someone can help, has anyone come across the same problem ignition then cutout with no fault code being thrown?
To my mind this would indicate something mechanical rather than electrical and there is maybe another solenoid or something that I am unaware of that would cause cutout approx threes seconds after ignition.
