vokera linea 24 not working
23 Jun 2008
Tyne and Wear
power to boiler was interupted, when the power was restored I used the reset switch to start up boiler sequence, but thre is no LED or green light.
or the spindle for the selector switch is broken.
I have checked the fuses in plug & next to the PCB all OK
I have also checked the spindle on the reset Knob that appears OK,
could the pump be at fault??the boiler clicks when you turn on the electric.
Still no LED or pilot indicator light.
you will have to check you are getting 240v to the boiler fuse and then to the pcb fuse. no green led will be from a total lack of power to the pcb if the spindle is ok.
