Bloomin Vokera
Im at a loss to this one and can't get is sorted. My boiler rests over night and central heating is fine. Turn the hot water on and the boiler fires up, water gets hot. Great, so you think. Problem is that, if i need to draw hot water off again within minutes, i have to wait till the temp gauge shows 20 degrees on it before the boilers lights up again waiting for the ignition to start. Wasting bowls full of water before it decides to fire up again. If i run the hot tap for a few seconds then shut it off and wait 10 minutes the water cools down and the boiler fires up straight away after turning hot tap on. If i dont carry out this step the boiler takes ages to light up again. Gradually getting worse and more annoying by the day. Please help.
