Hi
I have a problem with my Vokera 28e boiler I can get it to run and it fire up and circulates the hot water around all my rads it also delivers hot domestic water to my taps.
The problem is when the boiler shuts off on temperature it will not kick back up again and all the rads go cold until I turn it off and on again.
The pump and fan runs ok no problem the rubber tube to the differential pressure switch near the fan are all ok no holes.
I do not have a room stat I have thermal valve on all but one rad
I have also looped the time clock out to see if that was causing the problem but with no luck
Can anyone give me some guidance to my problem?
David
David
