I did 2 loads of washing, both were set on a 40 mixed fabric cycle & the machine did both loads fine but when I tried to remove the plug from the socket it was stuck solid in the socket, so I killed the sockets & after a lot of tugging & swearing I managed to get it out & I noticed that the black plastic around the bottom of the neutral pin had melted & the plastic round the pin was a browny colour. I then looked at the socket & plastic around hole where the neutral fits was mis-shaped & not straight like the other holes. I then tried to open up the plug to have a look & it was glued together but I managed to open it with brute force & the neutral wire was black & the plug had melted into the plastic around the wire.
Is the w/m at fault or the socket?
If it`s the socket thats faulty then am I safe using the other socket next to it?
Don`t know if it`s worth mentioning but whenever a bulb blows in my bathroom it knocks the main switch off.
