- Joined
- 1 Oct 2021
- Messages
- 1
- Reaction score
- 0
- Country
I'm using wago connectors where possible to wire up my new light fittings (with metal casing).
I'm using the 2-way / 3-way lever connectors for the supply/to switch/loop wires, and was hoping to use the 224 series connectors for everything else.
However, a couple of my lights have more than 2 earth conductors. I used an old fashioned terminal block for one of them, but was hoping there was a wago solution for the other. Is there any reason why I shouldn't use a 5-way lever connector to connect all the earth wires together (including the one from the metal casing)? I think my existing light is likely to have 4 earth conductors, but not sure until I remove sleeving.
Any other suggestions? Thanks in advance!
