An alternative might well be an SDS drill with rotation stop and a bit sush as the Armeg chasers. I use three different chasers (55mm, 30mm and 20mm skirtings) on a 3kg rotation stop hammer and they generate less dust than a chaser (chasers require a fine dust industrial vacuum cleaner) and aren't a wole lot slower
