Wall cracking
21 Apr 2015
Tyne and Wear
Hi All
I have a fire door from my kitchen to my garage
the breeseblock wall garage side seems to be cracked around the door frame from when the garage door has been slaming shut.
any ideas on how to repair / prevent further damage?
thanks
stop slamming the door, or use a door closer
If its just cement cracking, give the frame a bit of a pull to see that it is secure.
If that's fine, rake out the cracked mortar and repoint.
If you want, Fischer do cement in a tube applied by a silicone gun, courtesy of Wickes. It isn't an adhesive though!
A closer will prevent re-occurence.
John :)
