- Joined
- 2 Jun 2023
- Messages
- 57
- Reaction score
- 7
- Country
Hi all, am looking at buying a property built c 1900-1910 where some courses of bricks next to a former chimney breast appear to be deflecting inward. Survey [level 3] says
"To the rear wall, there is evidence that makes us consider that there was a chimney stack, which has been removed and there is a lead weather detail in place to cover the protruding chimney breast, which remains. It does appear that the chimney breast wall is inwardly deflecting off vertical to the upper brick courses. This wall, as it is no longer supporting a chimney breast, requires stabilising, by way of removing the deflecting brick courses and rebuilding that upper section of wall back to vertical, which is both structurally sound
For a building contractor to remove the deflecting brick courses to the rear projection wall and rebuild to verticality. This may involve some form of helifix wall ties embedded in the mortar courses to stabilise this wall. We estimate the cost of this repair to be around £1,500 Plus VAT. (See photo A)"
Originally the surveyor was saying it needed a structural engineer to take a look, but now, after looking further and considering there is no longer a chimney above supported by this wall, he is saying making good the affected courses will suffice.
Photos attached.
Please can you the experts here let me know whether they think the surveyor's new view and proposed solution is right, whether this actually does need fixing [as it must be only a slight deflection I think], if you think it could be something else. My only other thoughts are it could be poor original workmanship, it could be the pointing on the bricks in the corner of the building at the top have failed [as exposed the most], or it could be something to do with the roof structure supported by the wall [maybe more of the load goes into the corners if something has failed in the roof structure?] but you all know more about walls than me
as ever thanks very much for all contributions, it's very much appreciated
best
David
Photos attached.
best
David
