Morning all (why is it always silly o'clock when I'm on here???)
Nearly 12months ago the missus asked for wall lights in the room we were doing up.. Well 12months on, due to various unrelated issues I'm just getting to finishing this little job off..
I've got 2 wall lights that only require a L&N connection (pushfit in the fitting (ugh)). All the cables have been run, main loop, switch and 2nd light conection. Now I know I could have run the loop back to the switch (just for this light setup), but I wanted to keep with the current wiring of looping in and out of the ceiling roses.
Originally I was going to sink 1g plasterboard boxes and use Helacon connectors to join everything. But now I'm at the moment of truth I'm wondering if all will fit neatly in the box using the helacons. Could I use say an Ashley 501 downlighter JB as it would be accessable (through hole in wall) rather than the helacons?
I did consider crimping but I can't find info nor work out in my head how I'd get all the connections made with crimps.
Advice as always noted and greatly accepted.
Rob
Rob
