I want to mount bookshelves on an internal wall in a mid-90s build apartment. I plan to use the metal vertical rails with brackets and fill them with books - so it will be heavy.
Here's the problem - I can't determine what kind of wall material it is. If I knock on it, it sounds hollow, or at least more hollow than the external walls. But if I drill into it, it seems to be solid all the way through to the next room - about 6 inches. I have tried this in three separate locations, 6 inches apart vertically and horizontally, to check if I was drilling into wooden battens.
Does anyone have any clue as to what kind of wall this is? And if it would support heavy bookshelves?
Many thanks for any advice.
D.
D.
