I am decorating and updating a loft room for my three year old son.
At the moment, the only heat source is a convection heater with a timer and a variable heat setting. It is a Glen 2172 which I believe is a 2Kw heater.
The previous fittings were into the plaster board and had been badly fitted and were half out. In order to make it more secure I screwed a bit of MDF to the wooden frame behind the plaster board and the wall brackets to that. Hey hold the heater about 15mm away from the wall / MDF.
The heater heats the room very quickly and has only ever been set to around level 2 and on for an hour or so in the morning. I dont see it ever being put on full whack or on for a prolonged period of time. (It is now quite well insulated up there
Before I finish the room up and put my son in there, I just wanted to clarify a couple of points:
1. I understand MDF to be non combustable. Are there any issues with mounting the heater on the wall to MDF in this manner?
2. I obvioulsy don't want my sone to touch the heater or be able to play with the controls and dont really like the mesh 'covers' you can buy so would I be ok getting a big MDF radiator cover to ensure a good distance all round the heater? If so, what would you suggest the minimum air space should be?
I cant find the instructions on line but similar heaters talk about clearance of a few inches up to a meter!
John
John
