wallpaper adhesive for edges
16 Oct 2007
Manchester
Over the weekend I put up some medium weight wall paper in the bathroom. I used solvite wallpaper adhesive (powder mixed with water).
Two days later and some of the edges are peeling back. I am wondering if there is a stronger/more sticky adhesive I can use specifically for the edges to put them back down again
thanks all :)
This is a problem that occurs quite often even I have often been guilty of doing such.
Take a trip to either your local Dec outlet or one of the sheds, and get yourself a tube of border adhesive. Useing your finger slightly dampen the back of the raised seams, allow to soak for two mins then adopt the same approach with the adhesive. Problem solved.
Dec.
