Hi all.
Just wondering about Wallrock as insulation. I've been gradually tackling the condensation/mould in our house. It has 9" solid brick, so North-facing walls can be pretty cold. Solution for me was to strip plaster off, put battens up, fill with Celotex sheets and plasterboard over. Rooms are warmer, no cold wall for the water vapour to dew on and I've even cleaned the trickle vents to improve ventilation for that vapour to escape.
The last (and worst) room though is the bathroom. It has two external walls, one of which suffers very badly from mould and it's not good for the old asthma! First job is to insulate the toilet cistern with foam (to stop water beading on the outside), the last job is to insulate the walls... and this is where I need some advice.
I don't fancy losing 45mm+ of space for Celotex/plasterboard again, so I was wondering about the effectiveness of Wallrock? Believe it's only 3-4mm thick but made from wood/fabric fibres interwoven together... Has anybody used this stuff? Only need it to make the walls a little warmer so condensation doesn't dew on it.
Just looking out there to hear of any experience of it really! Thanks.
