warm deck
8 Jul 2009
Hertfordshire
Hi folks
Is a warm deck necessary to provide adequate ventilation for a flat roof garage which is being converted into a music room (not accessible from inside the house) ?
If so,can this be achieved without having to build up the roof ?
Really grateful for opinions on this!
cheers
You can't form a warm deck retrospectively without taking the existing deck off.
If you can't ventilate the roof void, then you will have to completely fill it with insulation, and fit a vapour check barrier or plasterboard. And if the joists are less than 150mm deep, you will probably have to insulate the underside to prevent pattern staining
