Hi I am a newby to the site so please bear with me. I have a 20 year old Stelrad gas system with 13 radiators. It has worked beautifully until recently when it decided to heat some rads and not others and no hot water. Here is a list of what has already been done within the last month
Powerflush
New grundfos pump (there is a myson aerjec) on the system if that helps.
Thermostatic valves to all rads
New ball valve to header tank
New automatic bleed valves to two downpipes in loft which feed kitchen and downstairs loo.
We now have hot water but we also have
Hot water coming out of the vent into the header tank, not boiling or steaming just warm so assume normal?
The upstairs rads need constant bleeding, you can hear them emptying as soon as the boiler comes on, even for hot water only. Does this mean that the boiler needs bleeding or is that a silly question?
When the rads are bled it is not just air in the rad it seems to bleed the whole house!! It seems that there is more air coming out than would occupy the radiator and it comes out at great speed!
I have turned all the rads off and then opened them one by one and can get heat to each one in turn.
I have turned the pump down from III to I, having looked at a forum suggestion.
I really do not know what else to do, does anyone have any ideas? In woman speak please!!!!!
I really cant afford a new boiler.
Powerflush
