I have a warmflow 70/90 boiler, some 16 years old, rated at 84.7 % efficiency and has never failed. I replaced the baffles today as per diagram in the warmflow manual. They were actually ok, Two of them were starting to warp in parts, one was fine with the boiler was surprisingly clean considering it was never serviced before.
There are 3 baffles in total with a plate mounted on top of the last baffle. I could not help but notice there is enough room in the combustion chamber to add another baffle if I modify slightly (split into two parts to allow for entry through the top lid)
My question is would adding a 4th baffle in the correct orientation improve the boiler efficiency by allowing longer time for heat to transfer to the water jacket. The fact the boiler is pretty clean inside and the original baffles were not bad makes me think this thing is not over heating or over worked and might be able to handle another baffle??
I am sure the warmflow design engineers characterised this model fully to squeeze as much efficiency out of it as possible, but maybe not???? as energy effeciency was not a big issue back in the early 2000’s when this model came out? Just wondering if anyone out there has tried this before?
Thanks for any comments.
Patrick
Patrick
