Was planning to fit an open vented system and bought a second hand boiler which has 3 22mm connections , can anyone explain these as I think I only need 2 for the rad circuit.
Thanks in advance
Thanks dcawkwell , how would I identifi which one to cap ? Theres 2 on the lefthand side and on the right hand side the drain is on the bottom with the other 22mm on top of the boiler.
