Washer or no Washer, that's my question !
  • Thread starter Thread starter Blueflash
  • Start date Start date
B
Blueflash
Hi, I have just bought a Mira Monobloc mixer tap which i will attempt to fit tomorrow.
I have notice that the flexible hoses have no washers fitted in the threaded couplings, is this correct ? Sorry, i am not a plumber, as you will have guessed !
All positive help appreciated.
Thanks,
Dave
the ends that go into the tap body or the other end?
two small o rings should be at the tap body end (usually)
if its the other that joins to the pipe/ fitting. they are usually nuts and olives that go onto the pipe or they will be 1/2 inch male iron connections.
they will need connecting to the pipe with a 1/2 inch female iron to 15mm copper adaptor. they come in straight or bent options.
https://www.screwfix.com/p/female-c...gclsrc=aw.ds&dclid=CJaTi-39gNsCFecD0wodXpAEdA
https://www.googleadservices.com/pa...hUKEwj1_PKL_oDbAhVFJcAKHaAlDmUQ9aACCEU&adurl=
oh you'll need some ptfe too.
(i'm crap at links)
Post a pic to be sure ,but you will almost certainly need washer to seal .
Thanks guys.
Mc - i have the threaded adaptor on the existing copper pipe and lots and lots of ptfe !
Terry - the taps came with a threaded coupler on the end of the hoses and a female coupler with olives to fit to the 15mm pipe, just thought it was odd not having washers in hose ends :confused:
Thanks again for your help,
Dave
