Washing machine - cannot access pump :(
20 Oct 2008
Lincolnshire
I have a Zanussi zwf 1621w and when it is finished its wash we get 2 x beeps and some of the water isn't drained.
A check of the manual indicates that the pump may be blocked (2 x beep error code).
The manual says in the bottom right corner of the machine, open the service flap, use the emergency drainer to empty the machine - done all that - machine is emptied.
It then says to remove the pump impeller cap in the bottom right of the machine - done that - it then says to pull out the pump itself and remove any blockage - i can't do that!
Like i said i have removed the cap and behind that is the impeller, but i cannot remove it - it won't budge. Any ideas?!
Ta!
This would be better posted in appliances, does the impeller rotate, if it's seized with no sign of blockage then you may need a pump replacement.
sorted - needed brute force to get the thing out. Didn't realise i should be cleaning this on a regular basis.
