Hi everyone
My first time here and a bit of a tale of woe.
I had a laundry room built in my basement and it looks fab. but I'm getting bad smells and I think it is because a p trap was not fitted to the waste.
(and it is here dear readers that I curse myself. Back story: the builder turned out to be a real cowboy who cut corners at every opportunity. When I saw that he had put the drain for the washing machine behind a stud wall, and that it emerged from the plasterboard at about the 70 or 80 cm above the floor, I asked him whether a trap was in the line and he said "yes", and like a fool I believed him. )
So now I have bad smells, a drain that looks like it consists of a straight pipe that emerges from the plaster board almost horizontally and appears to run in a straight line to the sewer some 2 meters away just below floor level. I would like to to add a trap that I can see and clean.
Questions I hope you can help with;
What are my options?
1) e.g. can I simply add a p trap without a stand pipe to the existing pipe that projects? Or could I create a very deep trap? Must there be a stand pipe?
2) Should the trap be anti syphon?
3) I guess, at the worse of my expectations, I might have to rip out the plaster board and re work the drainage but that sounds very expensive and messy.
Any advice is very much appreciated.
