I have a query about how water should drain away. We are told that best practice is to have a stack pipe higher than the drum leading down to a P trap then into the main drainage system.
This arrangement has been in place for over 25 years with only the WM outlet hooked into the stack pipe. The P trap became blocked and the WM continued to pump. Result a flood which wasn't found until later.
Trouble is it's 'out of sight out of mind'. Any other solutions?
