Does the water smell dirty? If so, it may be that dirty water is coming out of the drain into the waste pipe, and getting into the tub. This often happens if the drain hose has not been looped up enough
It might be you have an errant sock or something trapped between the drum and the tub, or under the agitator if a top-loader. In some cases wildlife might have crawled in.
If the water is orange (rust coloured) but does not smell dirty, it may be you have a piece of iron or steel trapped somewhere. This is often an underwire from a bra. If you fill a large glass jar with rusty water, the orange sediment will slowly settle to the bottom of the jar. This may take a day or so if it is very fine.
If you have a home with iron water supply pipes, inside or in the street, then rust may come through the pipes, especially if they have recently been disturbed or repaired, or if the water flow direction has been reversed (this is done periodically to prevent sediment or stagnant water accumulating in unused sections of the water main. In this case, just run the taps for a few minutes until the water runs clear. You neighbours will have had the same problem if it is the supply pipes.
is this a top loader?
