Hi folks - I've been looking through past threads with similar problems but can't find the answer. I'm planning a bit of a bodge, which I suspect may upset some of the purists among you...
I'm trying to plumb in a washing machine on the other side of the room from the dishwasher. I'm hoping to use a simple plastic y-splitter to divide the existing cold inlet pipe between the two machines. Because the other side of the room is a long way off I'd like to run 15mm plastic pipe under the floor. My problem is how to attach 15mm pipe to the male 3/4" screw fitting on the outlet from the y-splitter.
Does this connector exist, or is there any sensible way to connect an easily obtainable 3/4" female hose connector to 15mm pipe?
The alternative is to connect multiple short hose lenghts as described in other threads, but that seems rather untidy to me...
Thanks in advance, Nathan
