washing machine plumbing
As long as there is somewhere for the waste to drain to - and water supply pipes are there for it to connect to - you can have it far away from the sink as you like.
there is no drain near to where machine will be, so would a hole need to be made through wall into kitchen and and somehow fed to pipework under sink
HarrogateGas said:
if there is no drain near to where machine will be am i right in thinking that a hole would need to be made through wall into kitchen then fed somehow to pipework under sink. Sink is not near where hole would be made
