washing Machine sizes
29 Dec 2006
Edinburgh
I'm looking for a new washing machine on the internet. I'm confused by ths sizes given as the same machine is listed on different sites with different sizes
The space I have is quite shallow, so I dont want to get the wrong size machine
I'm using the internet because I'm disabled and getting out to and arounf show rooms is quite hard
Anyone know why there might be different sizes listed on different sites?
I think there are european standards on size,
how much is the variation?
is one company mesuring to front of knobs & all rear projections?
I always look on the manufacturers website once I've found what I want to buy. You can usually even download the instruction booklet so you can see official dimensions and features.
If its any help I found that Indesit seem to be quite shallow machines (front to back) compared to others.......
They are almost all sized to fit in a 60cm x 60 cm space under a kitchen worktop 85cm high. There are some unusually big large-capacity ones, e.g. 69x95x78 that you would need to put in a laundry room.
There are a few that are less deep and will fit under a 50cm drainer.
Sometimes the measurement will vary depending on whether you allow fot the pipes and cables that stick out of the back, but even with these, they generally fit 60 x 60 (this is 2 ft square)
p.s.. ub7rm is right! I looked up some Indesits on the "Which" site and they are 55cm deep while the Bosch was 59 cm. This is nearly 2 inches less. However none of the Indesits was a Best Buy.
If you can get to the library and consult the "Which" report it will give sizes as well as test results.
____________________
lynda, moderator
please see forum rule 20
