- Joined
- 27 Jan 2008
- Messages
- 29,792
- Reaction score
- 3,694
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I was answering a query, and I went to look at adverts for tumble driers, and failed to find how much power they used, they would state 4.5 kWh per drying cycle, but not how many watts they used. I was looking at air cooled condenser driers.
I know my own tumble drier uses around 1.7 kWh per cycle, and the one before a vented around the same, but there are other features like drum size and time taken, which means not a direct comparison.
What I needed to know, could it be set up and switched on, and then would start drying cycle once the socket was powered up, i.e. when running from an old economy 7 supply. Or did it have a timer to use a off-peak supply, and would it complete its cycle within an off-peak supply of 3 hours. They simply did not say on adverts or even down loading the user guide.
My own, will complete within my 5 hour window, but only just, as the on timer is in one hour increments, so the start time can be nearly an hour after off-peak starts.
I have to set the delay, as there are that many button pushes, my wife does not seem to be able to work out how to do it, and stays up until 00:30 to turn them on instead.
I now have a second battery, so they can deliver 5 kW, but to start with, it could only supply 3 kW, there is a back ground use of around 500 watts, where freezers etc turn on/off, so I would have wanted a unit with peak power of around 2.5 kW, and I can't tell.
Also want in summer to not use multi high powered items together, so will the washing machine and tumble drier used together exceed 4.5 kW leaving 500 watt for back-ground.
I simply could not answer the questions, as so little info given. Seems Curries staff eat all the instruction books from adverts, maybe I should shop there?
But the basic question, is how can one use less power when items don't publish what they use?
