Waste Connections
29 Oct 2006
Glasgow
Installing new WHB waste/trap but existing waste seems to be odd size(36mm).
Where can I get hold of 36mm waste pie & fittings/traps? tried B&Q but they only stock 32mm & 40mm.
Will a McAlpine compression fitting not go on? That's what we ususally convert bnq and Hoiwdens grey c*ap with.
Otherwise you can manage all sorts if you take out the rubber part of a compression fitting and bulk it up with ptfe then put it back.
