Waste pipe condensation
28 Aug 2008
Cumbria
Hello group, we have recently moved home into a small bungalow, when we moved in the bathroom was carpeted; we replaced the carpet for vinyl. During the fit I removed the toilet and replaced the 4” flexi waste pipe for new. A few days later I noticed water sitting around the base of the toilet, on inspection I could find no leaks, but the waste pipe was soaked with condensation, this was dripping onto the floor at the rear of the toilet. The toilet sits against an outside cavity wall with the waste pipe running approx 80ft to a septic tank which is 18yrs old. The bungalow has central heating fitted which comes on twice a day for 2-3 hrs at a time. Any advice on how to eliminate or even reduce the condensation would be appreciated.
Regards Otto, West Cumbria
First thing to do is apply drain dye to the toilet cistern and flush the toilet to make sure it not a leak.
Then open the window for fresh air.
Andy
Thanks for the advice Andy, I'm sure its not leaking, as I re-fitted it over a fortnight ago and the water hasn't got any worse, sometimes its not even there, surely if it was leaking it would be constant and my floor would be awash. Is opening the window to aid with the condensation?
Regards Otto
