Water Accumulators
22 Aug 2011
Tyne and Wear
Hi
Need some advice on the best way forward for water accumulators
We run a BnB(bnb_a) whereby guests stay in their own building (c/w shower, boiler etc). The water supplied is fed by the mains supplied to our house. This has worked fine in the past but we are now building another bnb building(bnb_b) to house more guests (4). This new building will have another shower and kitchen facilities
I'm currently investigating whether I need some form of water storage/accummulator to supply all three buildings without reasonable interruption to supply
Space is llimited to house anything sizeable in bnb_a. I can just about fit a 100ltr accumulator (1000mm x 530mm). Or more preferable would be a 50ltr accumulator in both buildings.
Is this a feasible solution and more importantly does anyone have any experience with these units - do they work?
Many thanks
Andrew
There are some calculations to do, based on existing main pressure & flow rate (Static & Dynamic) & the number of outlets (taps) & potential number of occupants, -however from your description and rule of thumb I would suggest a 500 Litre accumulator would be about right - 100Litre would only serve a fairly small load TBH! :wink:
Hi
Many thanks for the replies There is usually two staying but the max is four - every now and again we have four
Should i split the water accumulators (2x250) or just one big 1
I'm waiting delivery of a flow meter to do some calcs and then from there i can start. Been in touch with TWS (total water solutions) who require flow and pressure figures before proceeding
TWS are a fantastic company their advice will be gold dust Darren Cooper is an old friend of mine :wink:
Thanks for the heads up they seemed quite switched on. Just done a flow and pressure test
Pressure 3.6bar
Flow: 12.5 litres/minute.
This test was done at the stand pipe of the first bnb building. I thougt it best done there rather than at the house as this is where the accummulator will be situated
they would want readings from near the mains stopcock and also from a couple of outlets.
Your figures do not seem correct
3.6bar with 12.5 lt/min indicate a pipesize of less than 6mm.
I would guess you have given static pressure 3.6bar
You need to know what the pressure is when the tap is performing at 12.5lt as well.
TWS will probably suggest that you site the accumulators as close as possible to where you need to use the water.So that you get best effect
