I've got a small problem with my system. i could live with it, but its probably wasting energy....
The problem is that the hotwater is being heated when the central heating is running. If the hot water cylinder thermostat is turned down the water still gets hot if the heating is working. I think that this a problem with the 3way divertor valve. I've had to replace the motor on it once before as it had stopped working. Maybe the actual valve itself is failing? What do you think? Is there anything else that might cause this to happen? Maybe some other valves etc that I should be aware of.
Central heating with 8mm microbore to the radioators if that makes any difference.
Also, if I was to replace the whole valve can I replace it with a 3-way mid-postions type valve? I'd like to have independent control over the heat and water. I know that this would require a new controller aswell. Looks like the pipe work will all fit. Anything else to know if I was to go down this route?
Any advice here would be great
Alan
Alan
