Back in June we had a 15yrs old uPVC dg window with openings replaced with a new unit with no openings.
When the window fitters installed the new window they moved it out about 20mm. Their reason being that had they installed it level with where the old unit was we would see the old sealant which would look messy. Although I didn’t really want the window moved forward I accepted what they were doing as I assumed they knew better than me.
Now when it rains and the wind is in the wrong direction water dribbles down on the inside from where the beading touches the glass.
We have been in contact with the installers who sent a “surveyor” out. He took the beading off and confirmed that the frame was wet and water was getting in via the screw. He then went outside saw the tiles and felt that the water was most likely getting to the window frame via the gap between the tiles and the brickwork. He concluded that it was our problem and that we should seal the gap between the tiles and the brickwork.
To me that sounds like a bodge.
Never happened with the previous window unit so does seem to me to be caused by them, perhaps because they move it forward?
Not sure what the bit of wood is between the window and the tiles is for, the “surveyor” says it’s a batten for holding the tiles, I know its not that but does seem to be suffering from the water.
What long term damage is likely to be caused and what do you suggest we do?
