Hope this is the right category.
I've water dripping in continuously from the valve (?) The bit that fills the tank after flushing. As a result water is going in the overflow.
When I raise the float ball, it stops.
There is a fair amount of scale in the tank and parts.
I adjusted a nut on the handle to its limit but hasn't helped. The ball valve handle is plastic.
What can I do?
Thank you
What can I do?
Thank you
