Hi everyone, I have been experiencing a strange problem over about the past 3 months.
After the WC is flushed the water falls gradually over the next hour so until it is just above the start of the S-bend. It doesn't fall any further, presumably because it will just suck air instead.
I am used to this happening when there is a strong wind which causes suction in the pipework when it blows across the top of the vent pipe. But for the past 3 months it happens all the time.
There is no sign of a leak around the base of the WC. There is no blockage in the sewer pipe. Finally, in order to remove any doubt about the vent pipe, I placed a plastic bag over the top of the vent pipe and nothing has changed.
The water level falls about 2cm per half hour until it reaches the beginning of the S-bend.
I'd be very grateful for a solution because I can anticipate, when we are away for any length of time that we shall be greeted by some pretty horrible smells on our return.
Justasking
Justasking
