WATER FLOW NOISE
9 Mar 2013
Tyne and Wear
WHATS CAUSING THIS ANY IDEAS
NOISEY COLD WATER FLOW TO UPSTAIRS TOILET,TAPS CAN CURE THIS BY SHUTTING OFF WATER AT STOPCOCK AND DRAINING COLD WATER FROM PIPES BUT THIS LASTS ABOUT 3 WEEKS THEN NOISE ON WATER FLOW RETURNS.
CAPS LOCK IS JUST ABOVE THE SHIFT BUTTON NORMALLY, can you turn it off please.
What sort of noise ??
just noise of water flow through pipes but as I said gets louder after 3 weeks or so but can get it to quieten by draining pipes of cold water
Don't know then unless you fit a pressure reducing valve.
Is there any other restritions in the pipe, maybe a non return valve for example
have you fitted the PRV yet and has it worked am curious to know
