Recently noticed what appears to be water hammer in the pipe work when using the shower. Its a loud vibrating noise that last for approx 4-5 seconds stops and then starts again after about 20-30 seconds all the while the shower is on. Doesn't do it when the hot taps are used. In the downstairs shower the noise seems to come from above, definitely not next to the shower.
Also the noise occurs whether the heating / hot water is on or not. Recently had a new pump fitted but cant see that would be the cause. The hot water comes from a Megaflo cylinder located upstairs. Any advice or suggestions to resolve would be much appreciated.
Many thanks
Many thanks
