hi i am installing a electric unvented water heater.i was just wondering will the pipe work need an expansion vessel or will the pipe work be sufficent.The hot pipe run is 15mm copper with a total length of pipe of about 8m thanks peter
No expansion vessel is needed but the ones i have fitted over the years have required a pressure-reducing valve and one or two have needed a blow off into a waste pipe ?....The instructions will tell you
