Water in bathroom pull switch.
13 Jun 2007
Sussex
My daughter lives in a flat and my grandson let the bath overflow causing water to go into the flat belows bathroom pull switch.
I went round to take a look for the elderly gentleman in the flat below and when you pull the switch on the circular LED light fitting it comes on but when you turn it off the light keeps flashing. I removed the pull switch which was full of water, dried it out and put a hair dryer on it.
Now when you pull the switch on it trips the trip switch which it didn't do when it was full of water! There is a pair of wires twisted together and a single wire in the pull switch, if I choc bloc them together it puts the trip out. I can't work out why this is happening.
Light fitting dry. What I can't understand is why it puts the trip out now the waters dried out and not before.
I can get a picture tomorrow but basically there are two wires in the pull switch a single wire and a pair twisted together common and L1. If I join the wires together simulating the switch being pulled on it trips. It didn't trip when it was full of water just went from either the LED light being properly on or the LED light pulsing with the pull switch in the off position. I get that in the off position the water would form enough of a circuit to light a LED .
