Hello.
It's a Vaillant combi boiler and the problem started just as summer ended. The water goes cold (and the heating I think) whenever it chooses, which can be a few minutes or a few days. A simple press of the 'flame'button on the boiler (ecoTEC plus 831) gets the water hot again.
I don't think there is any leaking anywhere underneath. The pressure doesn't seem to be dropping either. It may have gone from around 1.5 to 1.1 but that's over several weeks. I topped it up to 2.0 (not on purpose) and it seems to be maintaining this pressure. When I say I didn't do it deliberately, I meant I turned the valves until it rose to 1.5 and then closed them, but the pressure then slowly climbed up to 2.0 on its own! The water is still going cold.
My main question is that as there are no error messages at all, could a LIKELY culprit be the pressure sensor and what other LIKELY causes could it be?
Thank you.
Thank you.
