if i am right in assuming its a condensing system boiler have you checked if the condesate pipe is running while the boiler is pressurised and switched off?
if the condense pipe is running whilst the boiler is off then you have a problem with your heat exchanger. to check this, pressurise the system then turn the flow and return pipes off underneath the boiler. if the pressure drops then the leak is in your boiler . as agile said check this before you get the thermal imaging camera. much cheaper.
it would be very unusual for the heat exchanger to have gone so quickly.
