Hi, I read in an earlier post that the water level in the tank should be 10 cm and that the ball valve should be adjusted to cut off the flow at this level. Can someone tell me why the tank only needs this level which seems quite low compared to the size/height of the tank. What happens if it is much higher, as it appears to be in my tank.
I am trying to decide whether I have a leak in the system, hopefully in the HW tank coil (as I have solid floors) and having tied up the ball valve arm the level did go down to about 10cm over about 24 hours, at which point I panicked and filled it back up higher. Is there a way of checking whether the coil is at fault?
Any help will be very much appreciated
Arni
Arni
