Hi, would appreciate some help please. I've had a look at other posts and am left confused.
We are having an unvented cylinder installed in our garage. Currently we have a vented cylinder on 1st floor.
The property was extended on ground floor to the rear. When doing this, they buried the water main under screed and teed off above around and feed it to the garage and put a stopcock in the garage. This run from the ground to the garage is about 1-1.5m in 15mm.
All the gas/heating engineers I've spoken to said I have 3bar pressure (when tap is ruining) and about 20-22litres/min.
Off this 15mm. They think this is sufficient to feed the UV cylinder but recommended we run a new connection from the outside valve on the footpath.
I've had quotes for between £1600-1900 to do this. It's a 15m run to the garage.
My question is, should I live with the small section of 15mm which will be uprated to 22mm and connected to UV cylinder or bite the bullet and lay the new pipe. I'm not really sure if it's worth the money.
Any advice would be greatly appreciated.
Cheers
Cheers
