Hi Everyone.
I have a 3 story house and want to split into a separate flat for each level.
When the tap is on downstairs there is no water upstairs and it all drains back down the pipe. got good pressure upstairs when nothing else is on. I have a 25mm alcathene pipe coming in to the house.
Just wondering what to do? put 2 t's on the main pipe for the 2 upstairs flats with a check valve on each one and some sort of pressure limiter on the bottom and mid flat to create some resistance so water will be available to the upstairs flat even when downstairs is full on? Put a water tank in the loft for top and mid flat? diden't want to do that really as might want to convert the loft later. cheers Chaps... mark
