Currently I'm having an 32mm pipe installed from the road (water board valve) to the house. However, the plumber has advised me to downsize the pipe when inside the property to 25mm and then place a stop tap.
However, my thoughts are as I have a 32mm to the house the pipe should be 32mm until the stop tap (i.e. no down sizing to 25mm), allowing me to utilise the full flow/rate rather then down sizing the pipe and then putting a stop tap. Am I correct? And should I insist on 32mm till the stop-tap?
Any advise much appreciated.
