Oh dear, where's D. W. Cockburn when you need him? He'd know what to do!
No.Even if a fault causes that part to introduce a potential into some particular location which would not otherwise be there?
It can.As above, if it is not an extraneous-c-p it can't.
Has anybody ever seen him and Bernard together at the same time?Oh dear, where's D. W. Cockburn when you need him? He'd know what to do!
So, then it IS an e-c-p.It can.
But for it to be an e-c-p it has to have the property of being liable to introduce a potential.
No, only if it is liable to introduce a potential.So, then it IS an e-c-p.
Dunno - I'm seeing the same problem.What has happened to the 'quoting'?
When clicking 'quote' on your post, my question which you quoted does not appear.
But the reasoning for not earthing the pipework in that case could also be used as an argument not to earth the metal casing of a class I appliance.That scenario is not required to be considered as it is deemed less hazardous than you touching the frayed lead and a wrongly bonded - earthed - isolated part.
But who goes around deciding or changing bonding arrangements on such unknown things?If the kettle lead is trapped under the water pipe then you may consider the scenario likely and earth the pipe
But they are not metallically contiguous items running all around the house.What you are saying is only answered by reference again to window frames, door knobs and spoons.
It was considered valid enough for decades when the wiring regs. specifically required the earthing of the whole metallic pipework system, metal tubs and sinks etc.Also, yet again, thinking of one unlikely occurrence when these rules would be better ignored is not a valid argument.
No. They are exposed-conductive-parts of electrical appliances and may become live because they contain live parts.But the reasoning for not earthing the pipework in that case could also be used as an argument not to earth the metal casing of a class I appliance.
Those designing electrical installations - and not bonding - earthing.But who goes around deciding or changing bonding arrangements on such unknown things?
No, but just as unlikely to become live and likely to be touched by someone grateful they do not provide a path of negligible impedance to earth.But they are not metallically contiguous items running all around the house.
I don't know why they decided that then but they were wrong.It was considered valid enough for decades when the wiring regs. specifically required the earthing of the whole metallic pipework system, metal tubs and sinks etc.
Sure, but the point I was trying to make is that if you're saying that pipework should not be earthed because of the possibility of somebody sustaining a shock by contacting some other live point while also in contact with that pipework, exactly the same argument could be made for not earthing anything else. Doesn't the earth on that metal-cased class I wall heater pose a similar possibility of shock to some live conductor as an earthed kitchen sink?No. They are exposed-conductive-parts of electrical appliances and may become live because they contain live parts.
Comparing with spoons, door hinges, and similarly trivial items is silly, because they're not expansive collections of metalwork which spread around multiple rooms of the house.I don't know why they decided that then but they were wrong.
Spoons again.
..but it is the most likely hazard against which we protect.Sure, but the point I was trying to make is that if you're saying that pipework should not be earthed because of the possibility of somebody sustaining a shock by contacting some other live point while also in contact with that pipework, exactly the same argument could be made for not earthing anything else.
Yes, but less likely a danger than not earthing it.Doesn't the earth on that metal-cased class I wall heater pose a similar possibility of shock to some live conductor as an earthed kitchen sink?
Not really silly.Comparing with spoons, door hinges, and similarly trivial items is silly, because they're not expansive collections of metalwork which spread around multiple rooms of the house.
Ok. They have changed their mind.The old wiring regs. contained a similar "segregate or bond" requirement for things, but also recognized the fact that effective segregation of an extensive metallic pipework system is not practical, and thus specified that it must be earthed.
You cannot. It is a compromise.If you are that concerned about the earth potential on the radiator pipes, kitchen sink, bath tabs, etc., posing a risk, what steps do you take to ensure that they can't be earthed by some incidental/accidental path?
I have previously stated that that would be a good thing to do.Do you insist on plastic couplings everywhere so that, for example, an earthed metal appliance placed on a stainless steel kitchen sink won't introduce earth potential throughout the plumbing? Do you insist on insulating couplings at the hot-water cylinder, so that pipework won't be earthed via the immersion heater connection?
It is a compromise - you may if you wish.Do you insist on something which ensures that a washer or cooker pushed up again the rim of the sink won't do the same?
Your socket on the left is wonky
Doesn't your understanding extend to understanding the difference between exposed-conductive-parts, extraneous-conductive-parts, and things which just happen to be conductive because they are made out of conductive materials such as metal?Doesn't the earth on that metal-cased class I wall heater pose a similar possibility of shock to some live conductor as an earthed kitchen sink?
So when the regulations change, and introduce a requirement for increased safety which you think is not necessary, you say "Pah - what a load of gonads, if it was OK in the past it must be OK now".The old wiring regs. contained a similar "segregate or bond" requirement for things, but also recognized the fact that effective segregation of an extensive metallic pipework system is not practical, and thus specified that it must be earthed.
Believe me that's the least of the problems with this awful kitchen...Your socket on the left is wonky![]()
