Water pipe knocking when hot water comes on
16 Oct 2008
Berkshire
I've been searching this forum but couldn't seem to find the answer to my problem hence posting this thread.
I refurbished my house recently and the hot water tank which was downstairs was moved in the loft by a plumber. It sits just underneath the cold water tank. The hot water is set on timer so boiler heats up the water only once in a day. Knocking/banging sound is coming up every time boiler starts heating up the water. It goes on for about 5 to 10 minutes and then everything goes to norm. This is happening only when the hot water is coming on and not with the central heating.
I hope you guys would be able to suggest something and I'm sorry if I've posted a question which have been answered in the past.
16 Oct 2008
Hertfordshire
Have exactly the same probelm. Its air trapped in the pipes. Also sometimes it can mean there's some rust in there. As there can be sediment that builds up in the pipes causing more pressure. Hence the pipes expand and contract and you hear the banging and clanging.
I've heard you can get you pipes cleaned with a high pressure water / chemical mix. It costs about £270 and takes between 3-7 hours to do. Not sure to be honest. But That banging is damn annoying! :eek:
3 Dec 2007
Essex
shouldn't be any air trapped in the system. unless its drawing it in the vent pipe.
and powerflushing is not done under high pressure.
16 Oct 2008
Berkshire
As I've set the timing for hot water, it comes on at 6am and within minutes the banging sound starts. Its a single bang sound with a delay of few seconds and it carries on for about 5 minutes. Then everything is back to normal. I just hope someone would suggest something to try here because its just really annoying because we need hot water in the morning and this banging sound always wakes me up way before I need to be woken up.
3 Dec 2007
Essex
have you checked all the pipes to the cylinder that one isn't banging on exspansion when first heating up.
16 Oct 2008
Berkshire
Thanks for your response. The problem is all pipes from upstairs to the downstairs where the boiler is are behind boxes so I don't have access to them. But I can see them all in the loft. I've this feeling its expansion banging but how could I confirm and rectify it?
9 Oct 2007
Hertfordshire
Why not delay the hot water coming on until you need to wake up. Then you get a double whammy, a "hot water alarm system combo"...do away with the pesky radio buzzer alarm on bedside table and you have more room for lots of other trash!
